Where Waterjet Cutting Fits in Propulsion and Engine Manufacturing
Posted on 11/10/2026 in Blog
Manufacturing propulsion and engine components demands more than dimensional accuracy. Material integrity, repeatability, and reliable downstream processing matter just as much. Abrasive waterjet cutting offers a useful process option, particularly for difficult alloys and complex profiles. Its strongest role is often not replacing every machining operation, but preparing components efficiently while avoiding the thermal effects associated with hot cutting processes.
Cutting Difficult Materials Without a Heat-Affected Zone
Abrasive waterjet cutting combines high-pressure water with abrasive particles to erode material along a programmed path. Unlike laser or plasma cutting, it does not produce the conventional heat-affected zone associated with thermal cutting. That distinction is valuable when processing a wide range of materials, such as titanium and nickel-based alloys, used in demanding aerospace applications, where changes to material properties can complicate subsequent manufacturing steps.
For engine manufacturers, the practical benefit is flexibility. A waterjet can profile different alloys without relying on a conventional cutting tool to remove all the surrounding stock. This makes it worth evaluating for expensive materials that are challenging to machine.
Applications Across Propulsion and Engine Components
The clearest opportunities are components produced from plate, sheet or pipe, along with blanks that will receive additional machining. Candidate applications include mounting brackets, flanges, support rings, and profiles for heat shields or exhaust assemblies. Suitability of abrasive waterjet cutting depends on the material, thickness, geometry, and engineering requirements rather than the component name alone. OMAX has a number of aerospace customers and suppliers using waterjet in fabrication processes that include cutting slots in stators as well as supporting tooling and fixturing applications, in addition to the applications named above.
Waterjet cutting also deserves consideration for preparing near-net-shape blanks for more demanding parts. Instead of milling an entire outline from oversized stock, manufacturers can waterjet the initial profile and reserve machining for precision surfaces, bores, threads, and interfaces. OMAX has customers that have driven significant material and process time savings cutting near net shapes in materials like Inconel®.
For turbine, combustor, or rocket propulsion hardware, this distinction is essential: cutting a useful starting shape is not the same as delivering a finished, flight-qualified component. Complex cooling passages, tightly controlled aerodynamic surfaces, and critical sealing features typically require other manufacturing processes.
Surface Integrity Still Requires Attention
Cold cutting does not mean that every cut surface is ready for service. Waterjet-generated striations and embedded abrasive can matter, particularly in fatigue-sensitive applications. Research conducted by the Pacific Northwest National Laboratory involving lightweight metal fatigue evaluated secondary treatments specifically to remove visible striations and clean up garnet embedment, demonstrating why the complete process matters more than the cutting step alone.
Accordingly, engineers should establish acceptable edge condition, finishing allowances, cleanliness requirements, and inspection methods before adopting the process. Precision or highly stressed features may need subsequent machining or surface treatment. Qualification should reflect the actual alloy, component geometry, loading, and operating environment.
Evaluate the Complete Manufacturing Route
The business case should compare total production cost, not simply cutting speed. Relevant factors include material utilization, programming, fixturing, abrasive consumption, finishing, inspection, and waste handling. A faster initial cut offers little value if it creates excessive downstream work.
The best approach is a representative trial: select a candidate component, define acceptance criteria, and compare the complete process with the existing manufacturing route. OMAX offers application consultation and test cutting services to support the evaluation process.
For propulsion and engine manufacturers, waterjet cutting is best viewed as a complementary capability—especially valuable when difficult materials, thermal sensitivity, and efficient blank preparation intersect.
Frequently Asked Questions
Where does abrasive waterjet cutting fit in engine manufacturing?
Abrasive waterjet cutting is a complementary process for profiling sheet, plate, and pipe and preparing near-net-shape blanks. In propulsion and engine manufacturing, it can leave precision surfaces, bores, threads, and critical interfaces for subsequent machining rather than attempting to produce every finished feature in one operation.
Can waterjet cutting process titanium and Inconel®?
Titanium and nickel-based alloys, including Inconel®, are candidates for aerospace waterjet cutting. The process avoids the conventional heat-affected zone associated with thermal cutting. Suitability still depends on material thickness, geometry, edge requirements, and the complete manufacturing route—not simply the alloy name.
Are waterjet-cut aerospace components ready for service?
Not necessarily. Avoiding thermal effects does not eliminate surface-integrity concerns. Striations and embedded abrasive may require finishing, cleaning, and inspection, especially for fatigue-sensitive parts. A waterjet-cut blank should not be confused with a finished, flight-qualified component; acceptance criteria must reflect its intended application.
How should manufacturers evaluate waterjet cutting?
Start with a representative component and defined acceptance criteria. Compare material utilization, cutting, fixturing, abrasive use, finishing, inspection, and waste handling across the complete process. OMAX application consultation and test cutting services can support this evaluation before manufacturers commit to a production route.
