Five Reasons Why Waterjet Is Strengthening Defense Manufacturing
Wednesday, February 11, 2026
Posted on 02/11/2026 in Blog
Image of aircraft carrier
Defense manufacturers operate within an environment defined by rapid change, tight tolerances, and rising material complexity. From vehicle armor to missile components to field‑repair tooling, every program depends on production methods that can adapt quickly without sacrificing accuracy or reliability. With the industry’s growing use of advanced composites, ballistic materials, engineered glass, and super alloys, many traditional cutting technologies struggle to keep pace. In contrast, abrasive waterjet technology has become a key solution across the defense sector thanks to its versatility, precision, and inherent safety advantages.
OMAX waterjet systems meet these demands by cutting virtually any material without altering its structural properties, supporting highly variable workloads, and helping manufacturers maintain throughput even amid workforce shortages. The following five capabilities illustrate why waterjet machining continues to strengthen defense manufacturing and why more shops are adopting the technology as a core part of their production strategy.
1. Cutting Virtually Any Material with No Heat‑Affected Zone (HAZ)
Defense programs increasingly rely on materials engineered for strength, resilience, or ballistic performance. Many of these (such as titanium, hardened steels, composites, and laminated glass) are challenging or impossible to machine with thermal or mechanical methods. Processes like laser or plasma risk introducing heat‑affected zones that weaken the part, cause microcracking, or alter the material’s carefully designed properties.
Abrasive waterjet cutting removes this risk entirely. As a cold‑cutting process, it produces no HAZ and does not introduce mechanical stress into the part. Whether working with stainless steel, super alloys, plastics, Kevlar, carbon fiber, ceramics, or engineered glass, OMAX waterjets deliver clean edges, tight tolerances, and repeatable quality. For defense contractors, this means mission‑critical components can be produced without rework, metallurgical concerns, or distortion.
2. Technology That Adapts to Constant Change
Defense manufacturing rarely stands still. Material lists evolve, design adjustments occur frequently, and programs may shift priorities with little warning. Shops must pivot quickly, sometimes machining parts without full knowledge of the exact material grade or composition.
Waterjet technology is uniquely positioned to support this level of variability. A single OMAX machine can transition between metals, composites, polymers, transparent armor, and experimental substrates without retooling or process changeovers. Cutting parameters are software‑controlled, meaning operators can load a new material, apply pre‑defined cutting models, and start machining with confidence.
This adaptability is especially valuable as the industry increases its use of near‑net‑shape manufacturing to reduce material waste. Waterjet’s narrow kerf and ability to produce precise, complex geometries help maximize material utilization while minimizing secondary finishing steps.
3. Advanced Software That Addresses Skilled Labor Shortages
Like many sectors, defense manufacturing faces ongoing labor shortages, particularly in machining and fabrication roles that require specialized training. The ability to maintain productivity without relying solely on veteran operators is increasingly important for both prime contractors and their supply chain partners.
OMAX addresses this challenge through the easy-to-use, easy-to-learn IntelliMAX Software Suite, which integrates CAD functionality, automated toolpath creation, and optimized cutting parameters that simplify operation. The software helps new operators produce high‑quality parts with minimal trial‑and‑error, and experienced technicians gain finer control over advanced applications.
For shops requiring elevated automation, the OptiMAX series incorporates real‑time sensors, linear encoders, and the IntelliTRAX drive system. These technologies deliver consistent accuracy while reducing operator involvement, making it easier to maintain output even as staffing levels fluctuate.
4. Improving Efficiency While Reducing Operating Costs
Efficiency and cost control are always priorities, but in defense manufacturing they become critical.
Waterjet systems help reduce operating costs in several ways:
  • Lower consumable usage thanks to simple abrasive and nozzle components
  • Shorter cycle times on intricate geometries due to precision motion control
  • Minimal secondary processing, with smooth edges that often require no further finishing
  • Flexible batch sizes, enabling both rapid prototyping and reliable high‑volume production
The ability to handle diverse materials on one platform reduces the need for multiple machine tools, consolidates floor space, and simplifies training and maintenance. These combined efficiencies support program responsiveness and help shops stay competitive even when contract requirements fluctuate.
5. Safer, Cleaner, and More Reliable Production
Workplace safety is a foundational requirement in defense manufacturing, where personnel often work around hazardous materials, heavy equipment, or sensitive components. Unlike thermal cutting technologies, abrasive waterjets produce no fumes, particulates, or sparks, creating a cleaner workspace and eliminating the risk of heat‑related hazards.
Waterjets also perform reliably in abrasive or environmentally challenging manufacturing environments. The IntelliTRAX drive system supports consistent accuracy even in high‑debris applications. This reliability is essential for machining aerospace engine components, armor plating, structural vehicle parts, and other mission‑critical hardware.
Because maintenance primarily involves replacing mixing tubes, nozzles, and standard wear items, downtime is minimal and predictable. This provides manufacturers with the confidence that their cutting capability will remain available when needed most.
A Proven, Future‑Ready Solution for Defense Manufacturing
From rapid prototyping to full‑scale production, abrasive waterjet systems provide defense manufacturers with a versatile, accurate, and resilient platform capable of meeting today’s requirements and adapting to tomorrow’s challenges. OMAX waterjets offer broad material compatibility, preserve the integrity of advanced engineered materials, and support operators of varying skill levels while reducing operational costs and improving safety.
As defense manufacturing continues to evolve, OMAX provides the cutting capability that helps programs remain efficient, agile, and ready for mission success.
Learn more how Waterjet can upgrade your defense capabilities
