Waterjet Cutting Thick Metal: Practical Tips for Faster Production
Posted on 11/03/2026 in Blog
Most shops are not asking, “Can the machine cut this?” They are asking, “Can we cut this fast enough, hold the edge we need, and avoid creating extra work after the part comes off the table?”
With thicker material, every machine setup choice has more time to show up in the cut, from abrasive flow and stand-off to taper control and edge quality. On an OMAX system, those setup choices are supported by machine guidance, software controls, and repeatable process data. Mistakes or misalignment on configuration could mean excess taper or a rough finish.
That is why the best place to start is not the machine’s maximum capability. It is the finished part. Decide which edges need a premium finish, which surfaces can run faster, and where extra cleanup would cost more than slowing the cut in the right place. OMAX CAD software helps make those decisions part of the program instead of leaving them to guesswork at the table. From there, build the program around the requirement instead of treating every edge the same.
Can Waterjet Cut Thick Metal?
Yes. Abrasive waterjet can cut thick metal reliably. In production, the goal is to cut it fast enough, cleanly enough, and consistently enough to meet the job requirements while still working within the shop’s available time, machine capacity, and tools on hand.
OMAX waterjets can cut very thick material when the application, machine configuration, and available cutting time support it.
How Abrasive Waterjet Cuts Thick Metal in Shop Conditions
In abrasive waterjet cutting, the water accelerates the abrasive and the abrasive does the cutting. That is why the process can handle hard metals without introducing heat into the part. For thick metal, that matters because the cut has to stay stable for a longer distance through the material, and OMAX waterjets are built around that need for consistent, controlled cutting.
Because waterjet is a cold-cutting process, it does not create a heat-affected zone. There is no thermal distortion, hardening, or edge condition that has to be managed later. For stainless, aluminum, titanium, and other sensitive materials, that can make the difference between a clean blank and a part that needs extra work before the next operation.
OMAX waterjets are commonly used on carbon steel, aluminum, stainless steel, titanium, and tool steel. On thick stainless and titanium, the lack of heat input helps preserve material properties near the cut line, which is one reason waterjet often gets used before machining, welding, or forming.
Where Abrasive Waterjet Fits in a Thick-Metal Process
That does not make thick plate a bad fit for waterjet. It just means you need to decide what the waterjet is doing in the larger process. Sometimes it cuts the final profile. Other times it creates a near-net blank that saves time before milling, drilling, or finishing.
Near-net shape cutting is often where the time savings show up. Rather than asking a mill to remove a large amount of stock, the waterjet can rough the profile close to size and leave the final tolerance work for the next operation.
The Variables That Control Thick-Metal Speed, Taper, and Edge Quality
The main variables are not complicated, but they do stack on each other. Material, thickness, geometry, pressure stability, abrasive flow, nozzle condition, traverse speed, and quality level all affect the final cut. OMAX systems bring those variables together through the machine, pump, cutting head, and IntelliMAX software, so the operator has a clearer path from setup to finished part. If one of them drifts, the part usually tells you.
Pump Output and Stable Pressure
Pump horsepower helps drive cutting speed, but the right pump design depends on the work. The EnduroMAX direct-drive pump is built for efficient abrasive cutting, delivering continuous pressure up to 60,000 psi, strong nozzle horsepower, and long intervals between maintenance. For shops cutting thick metal with abrasive waterjet, that efficiency can translate into faster processing and lower operating costs. The DynaMAX intensifier pump is designed for stable, consistent pressure during long production runs and is a strong fit for water-only cutting, multiple cutting heads, and applications that benefit from closed-loop pressure control. In either case, stable output is what keeps kerf width, edge quality, and cycle time predictable.
Abrasive Delivery, Orifice, and Nozzle Condition
Abrasive is not just a consumable. It is part of the cutting system. Grain size, dryness, hardness, and steady flow all affect the edge. Wet abrasive, inconsistent feed, or worn nozzles can make a good program look bad.
Piercing, Stand-Off, and Lead-In Strategy
Stand-off is another small setting with a large effect. Too much gap weakens the jet before it reaches the material. Too little gap increases the risk of clogging or crashing the setup. Set it to the machine guidance and check it before production, not after the first bad edge.
Taper Compensation and Cutting-Head Motion
A small amount of taper is normal in waterjet cutting, and thick plate makes it more visible. The TiltaJET cutting head helps correct that by tilting the jet based on cutting speed, so square-edge requirements can be handled by the cutting head instead of by slowing the whole job down.
Process variable
What to verify for thick metal
Effect on speed, edge quality, or taper
Production action
Material and thickness
Correct alloy and thickness entered in the software cutting model
Thicker and harder material cuts slower; titanium is an exception
Confirm the material selection matches the plate before programming
Pump pressure consistency
Stable output across the cut, not just peak pressure
Fluctuation varies kerf width and edge quality
Monitor pump stability
Abrasive type and flow
Grain size, hardness, dryness, uninterrupted feed
Inconsistent flow causes poor edges, waste, and clogs
Use the specified abrasive and verify continuous delivery
Orifice and nozzle condition
Wear against logged machine hours
Wear degrades focus, accuracy, and taper
Replace on an application-specific predictive cycle
Pierce strategy
Pierce location and  software pierce settings
Poor piercing damages the edge and slows cycle time
Utilizes automatic pierce-speed selection; place pierces on scrap side
Separation speed
Quality level selected in software
Faster speed increases striation and taper
Set the quality target to functional need
Lead-ins and lead-outs
Entry and exit path placement
Pierce marks and slowdowns can mar the finished profile
Route lead-ins and lead-outs onto the scrap side
Taper-compensating cutting head
Whether square edges are functionally required
Tilting the nozzle removes taper on thick plate
Upgrade to TiltaJET where fit-up demands square edges
Use the table as a setup check, not a theory exercise. If a cut starts drifting, these are the first places to look.
Build a Faster Thick-Metal Cutting Plan
A faster thick-metal job starts before the nozzle turns on. With OMAX, the most important decision is still what the finished part really needs, because speed only matters when the part comes off the table ready for the next step.
Set the Finished-Part Requirement Before Programming
Separate the critical edges from the noncritical ones. Weld-prep edges, visible surfaces, and tight dimensions may need a better cut. Stock that will be machined later probably does not.
If the next process will finish the part, leave the right amount of stock and let the waterjet do what it does well: remove material quickly without heat.
Use CAD, Simulation, and Nesting to Protect Material Yield
IntelliMAX helps by tying the cut path to material type, thickness, and quality level. That makes thick-metal work more repeatable, especially when the same alloy and part family come back through the shop.
Choose a Production Quality Level Instead of Over-Specifying Every Edge
Do not over-specify every edge. A production part may have one or two surfaces that need a premium finish and several that only need to be clean, accurate, and usable. That is where throughput is won.
An abrasive waterjet can cut multiple blanks from large raw sheets with little setup and fixturing time, and it can process materials that are difficult to machine on a CNC mill without changing tooling.
