Guide to Waterjet Machine Automation Using IntelliMAX
Posted on 08/11/2026 in Blog , Waterjet cutting
image of IntelliMAX software
Waterjet shops are being asked to produce more parts, hold tighter tolerances, and keep lead times short, often with high operator turnover. That's one reason automation has become a growing focus across manufacturing. The right software can remove much of the manual work from programming and machine operation while helping maintain consistent results.
The OMAX IntelliMAX Software Suite is built to close that gap by automating the workflow from design import through finished part. Instead of relying on multiple programs and manual adjustments, shops can move from a CAD file to finished components with fewer steps, greater consistency, and more predictable results.
How IntelliMAX Automates the End-to-End Waterjet Workflow
Waterjet machine automation is only as good as the software behind it. A disjointed workflow that requires separate CAD, CAM, and machine control programs creates opportunities for errors, delays, and rework. OMAX IntelliMAX brings those functions together within a single Windows-based software environment, allowing operators to design, optimize, and cut parts from one platform.
Here's how the process works on the shop floor.
Step 1: Design Import and Toolpath Creation in OMAX LAYOUT
Automation starts with getting geometry into the software quickly and accurately. OMAX LAYOUT is the CAD/CAM module within IntelliMAX that is purpose-built for abrasive waterjet machining. It includes standard drawing and editing tools along with waterjet-specific features such as cut quality settings, toolpath fonts, and gear and rack generation.
LAYOUT supports standard 2D DXF files along with advanced 3D formats from leading CAD platforms, such as SolidWorks and CATIA. This broad compatibility allows shops to work with existing engineering workflows while minimizing file conversion issues.
Once geometry is imported, IntelliMAX automates many of the programming tasks traditionally a manual process. The software generates lead-ins and lead-outs and builds the complete cutting path for the waterjet system. Rather than manually programming every detail, users can focus on part setup and production.
Step 2: Path Optimization with the OMAX Advanced Cutting Model
The real value of OMAX IntelliMAX lies in the Advanced Cutting Model.
Rather than relying on operator experience and trial-and-error adjustments, the software predicts how the abrasive waterjet will behave in a specific material and automatically applies the speeds, accelerations, and motion control settings required to produce an accurate part.
As an abrasive waterjet moves through material, the stream bends and changes shape. Jet lag, taper, and material variations can all affect cut quality if they are not properly compensated for. IntelliMAX automatically accounts for these factors before cutting begins.
The Advanced Cutting Model continuously adjusts machine movement to optimize throughput without sacrificing accuracy. Features such as automatic corner passing allow the machine to maintain higher productivity while preserving part quality.
By using a proven mathematical model developed specifically for waterjet machining, OMAX systems can produce accurate parts on the first attempt while reducing setup time and operator intervention.
Step 3: Machine Control and Execution in OMAX MAKE
OMAX MAKE is the control software that converts the optimized toolpath from LAYOUT into machine motion.
MAKE controls nozzle movement, abrasive delivery, high-pressure water flow, and the machine performance settings generated by the Advanced Cutting Model. Automatic adjustments for speed, acceleration, piercing, and cornering occur in the background while the machine executes the program.
Because programming, optimization, and machine control all occur within the OMAX IntelliMAX environment, shops benefit from consistent performance across operators, shifts, and production runs.
Key Automation Features in OMAX IntelliMAX
The workflow above is supported by a collection of automation tools designed to eliminate manual processes throughout production.
Automated Nesting and Material Yield Optimization
Material costs represent a significant portion of many waterjet jobs. To help reduce waste, OMAX IntelliMAX is compatible with both ProNest and ProNest LT automated nesting solutions.
These tools automatically arrange parts on a sheet to maximize material utilization and improve productivity.
Benefits include:
  • Higher material yield per sheet
  • Reduced scrap and waste
  • Improved efficiency for production runs
  • Remnant tracking and reuse
For shops processing expensive materials, even small improvements in nesting efficiency can have a meaningful impact on overall profitability.
Automatic Taper Compensation and Multi-Axis Cutting
Every abrasive waterjet cut naturally develops some degree of taper. OMAX IntelliMAX addresses this challenge through integration with the OMAX TiltAJet cutting head.
Using data from the Advanced Cutting Model, the system automatically tilts the nozzle based on cutting speed and direction to compensate for taper during cutting. The result is a squarer edge without requiring slower cutting speeds or secondary machining.
This combination allows manufacturers to create:
  • Bevels
  • Chamfers
  • Countersinks
  • Weld-preparation edges
  • Complex 3D features
When paired with a Rotary Axis system, OMAX waterjets can also process tube, pipe, and bar stock as multi-axis cutting applications.
Automated Job Costing and Time Estimation
Successful shops need more than accurate parts. They also need accurate quotes.
OMAX IntelliMAX provides detailed cutting time and cost estimates before production begins. Using material type, thickness, and required edge quality, the software calculates:
  • Estimated cutting time
  • Abrasive consumption
  • Pierce requirements
This information helps shops create more accurate quotes and improve production planning.
Instead of relying on historical estimates or educated guesses, estimators can base pricing on actual machine performance data generated by the OMAX cutting model.
Machine Monitoring with OMAX IntelliVISOR
Automation does not stop once the cutting program begins. IntelliVISOR comes standard on the OptiMAX systems and is an option for other OMAX systems.
OMAX IntelliVISOR provides real-time machine monitoring and performance reporting to help operators maintain productivity and avoid unexpected downtime.
The system can:
  • Monitor machine performance
  • Generate maintenance alerts
  • Support preventative maintenance planning
  • Enable remote machine oversight
By providing visibility into machine health, IntelliVISOR helps shops schedule maintenance activities before issues become costly interruptions.
How OMAX IntelliMAX Compares to Other Waterjet Software
Several CAD/CAM platforms support waterjet cutting applications. Each takes a different approach to programming, optimization, and machine control.
The table below highlights some of the key differences.
Feature
OMAX IntelliMAX
CAD/CAM Integration
Integrated LAYOUT CAD/CAM environment with support for DXF, DWG, and over 50 other file types.
Integration varies depending on originating file software version. Can be tricky.
Cutting Optimization
OMAX Advanced Cutting Model based on waterjet-specific cutting data
Algorithm-based approaches vary
Automated Nesting
ProNest and ProNest LT compatable
Usually supplied by 3rd party integrators
Taper Compensation
Automatic through OMAX TiltAJet integration
Available on select systems
5-Axis Programming
VersaJET support with bevels
Capability varies by platform, make and models
Cost Estimation
Built-in cutting time and abrasive consumption calculations
Available on some platforms but often not designed for Waterjet quoting.
Machine Monitoring
OMAX IntelliVISOR monitoring and alerts standard on OptiMAX and optional upgrades for other OMAX machines
Available on select systems but usually at additional cost
Integrated Workflow
One environment from programming through cutting
Require multiple programs
While third-party software and robotic waterjet solutions are available, OMAX IntelliMAX is designed specifically around OMAX waterjet systems. That close integration allows software, motion control, and machine performance to work together as a unified platform.
Practical Ways to Improve Shop Floor Efficiency with OMAX IntelliMAX
If your goal is improving throughput and reducing operational complexity, consider using IntelliMAX in the following ways:
  • Automate repetitive tasks: Use the OMAX Scripting environment to streamline recurring jobs and support integration with automated material handling systems.
  • Accelerate operator training: Enable new operators to move from CAD file to finished part with less reliance on years of waterjet programming experience.
  • Improve quoting accuracy: Generate estimates using cutting model data rather than assumptions.
  • Reduce downtime: Use IntelliVISOR alerts to schedule maintenance before failures occur. Can be added as an option for OMAX and MAXIEM. Comes standard with OptiMAX.
  • Capture job-specific instructions: Store notes, pauses, and custom machine commands directly inside the toolpath using XData functionality.
For companies operating multiple OMAX systems, maintaining consistent software versions across the shop can also help standardize workflows and reduce training requirements.
Frequently Asked Questions About OMAX IntelliMAX
What is OMAX IntelliMAX?
OMAX IntelliMAX is an integrated software suite that automates the abrasive waterjet cutting process from CAD import through machine control. The software handles toolpath generation, cutting optimization, taper compensation, job estimation, and machine monitoring within a single environment.
What file formats does OMAX IntelliMAX support?
OMAX IntelliMAX supports standard 2D DXF files along with advanced 3D formats from leading CAD platforms including SolidWorks and CATIA, helping manufacturers move designs quickly from engineering to production.
How does OMAX IntelliMAX eliminate taper?
OMAX IntelliMAX works with the OMAX TiltaJet cutting head to automatically compensate for taper during the cutting process, producing more accurate edges without secondary finishing operations.
Can OMAX IntelliMAX run 5-axis cutting programs?
Yes. When paired with the OMAX VersaJET head, the software can generate and execute full 5-axis cutting programs for bevels, chamfers, countersinks, and other advanced geometries.
Does OMAX IntelliMAX support remote monitoring?
Yes. As an upgrade to your software packing, OMAX IntelliVISOR provides real-time machine status, performance monitoring, and maintenance alerts that help maximize uptime and improve operational efficiency.
Bringing Waterjet Automation Together
A waterjet becomes significantly more productive when programming, optimization, machine control, and performance monitoring are connected within a single environment.
By automating design import, path optimization, taper compensation, nesting, job estimation, and machine monitoring, OMAX IntelliMAX helps manufacturers improve throughput, reduce manual intervention, and produce more consistent results. Whether you're running a single machine or managing a larger operation, the software provides the tools needed to turn an abrasive waterjet into a more efficient production asset.
Explore OMAX Waterjets and the OMAX IntelliMAX Software Suite to see how an integrated approach to waterjet automation can support your operation.
