Introducing 100HP Direct-Drive Pump at IMTS
Monday, September 08, 2014
At IMTS 2014, OMAX Corporation revealed its new 100HP direct-drive pump with EnduroMAX® technology in Booth #N-6228. Show attendees discovered how the pump provides increased efficiency, improved reliability and lower operating costs by delivering more JetPower at the nozzle, equal to today's 135HP intensifier designs.
OMAX's 100HP direct-drive pump features the durable Inline 6 design, an evolution of the company's EnduroMAX design that provides smooth cutting, high reliability and easy modular maintenance. The addition of the 100HP model extends OMAX's line of EnduroMAX pumps, which includes 30HP, 40HP, and 50HP models.
The 100HP pump with EnduroMAX technology increases efficiency by delivering 30 percent more horsepower to the cutting nozzle, compared with a 100HP intensifier pump. This increase in JetPower creates a more powerful abrasive stream for faster cutting speeds and higher productivity, and the improved efficiency results in less wear and tear and maintenance. The pump provides a stable jet stream up to eight times smoother than intensifier pumps, significantly reducing wear on high pressure plumbing and fittings.
The 100HP pump also uses Variable Frequency Drive (VFD) technology that tailors power and water consumption to an application for powerful and precise cutting. With VFD technology, the 100HP pump has increased power and water efficiency and seamless pressure control, all while eliminating inrush current and reducing maintenance.
OMAX's direct-drive pumps, which have been proven in over 3,000 installations worldwide, use less electricity and up to 75 percent less water than intensifier pumps, making them environmentally "green" and lowering operating costs. In addition, their quiet operation makes for a safer working environment.
