How waterjets work
1. High Pressure Pump
The pump generates a flow of pressurized water for the cutting process.
2. Cutting Head
A cutting head is a standard requirement, but an add-on option to OMAX waterjets, a computer-controlled multi-axis cutting head permits angled cuts and can be used to automatically minimize taper for precise vertical cuts.
3. Abrasive Waterjet Nozzle
Inside the nozzle the pressurized water passes through a small-diameter orifice and forms a coherent jet of water. The jet then passes through a venturi section where a metered amount of granular abrasive is drawn into the water stream. The mixture of water and abrasive particles passes through a special ceramic mixing tube and the resulting abrasive/water slurry exits the nozzle as a coherent cutting stream of abrasive particles traveling at very high speed.
4. Catcher Tank
The water-filled catcher tank dissipates the energy of the abrasive jet after it has cut through the material being machined.
5. Abrasive Hopper
The abrasive hopper and associated abrasive flow control system provide a metered flow of granular abrasive to the nozzle.
6. X-Y Traverse System
A precision X-Y motion system is used to accurately move the nozzle to create the desired cutting path.
7. PC-based Controller
Advanced motion controllers for abrasive waterjet systems are PC-based and permit production of accurate parts with minimal operator experience.
Motion Control
Because the waterjet cutting medium is liquid and not static, a waterjet tends to undercut corners and swing wide on curves when moved as one would move a traditional rigid cutting tool. OMAX eliminates this issue by using an advanced computer model to accurately predict the motion and shape of the cutting stream and then by using a PC-based motion control system to compensate for undesired jet motion. The result is a fast, accurate part the first time. No trial and error and no need for an experienced programmer because the experience and the knowledge is in the control software.
Pumps
Waterjet systems rely on two main pump types: direct-drive crankshaft pumps and hydraulic intensifier pumps. Both generate ultra-high-pressure water, but they do so in different ways, which affects how they perform in daily operation, how they are maintained, and how they fit into production. Direct-drive pumps generate pressure mechanically using a crankshaft. The design is relatively simple, with few components and low energy loss through the system. A larger portion of the motor’s power is transferred directly to the cutting process, which supports efficient operation and can improve cutting speed in certain conditions. The mechanical layout also makes system behavior easy to understand during setup and troubleshooting.
Intensifier pumps use hydraulic force to increase water pressure. Instead of generating pressure directly, they amplify it through a hydraulic system. This approach allows the pump to maintain stable output as conditions change, such as during long runs, temperature shifts, or gradual component wear. The system continuously adjusts to maintain the target pressure rather than relying on fixed inputs.
Performance in Use
Direct drive pumps deliver smooth, continuous high-flow pressure with high efficiency, providing consistent and precise cutting performance.
Intensifier pumps deliver steady pressure across varying conditions, providing consistent, predictable cutting performance.
Maintenance and Serviceability
Direct-drive systems are straightforward to understand and troubleshoot due to their mechanical design. Maintenance tasks are typically simpler, with fewer system layers involved.
Intensifier pumps are designed to streamline maintenance. Accessible components, simplified seal replacement, and system feedback can reduce the time required for routine service and support more planned maintenance schedules.
All abrasive waterjet nozzles use the same basic operating principle as the liquid blasting nozzle, first patented in 1936 (Patent 2,040,715). The modern configuration is shown in the diagram on the right.
Note that for a water-only nozzle that is designed for cutting soft materials, the mixing chamber and tube are eliminated and the coherent jet of water alone cuts the material.
In order for the abrasive waterjet nozzle to cut efficiently and to increase component life, it is critical that the jewel orifice is carefully aligned in the nozzle body. All OMAX nozzles are factory-aligned and individually tested to ensure efficient cutting and long life.
Related Questions
How much maintenance is involved with operating a waterjet?
Most of the maintenance on an abrasive waterjet involves servicing the pump and the cutting head. The exact type and frequency of maintenance will depend on how the machine is used (pump pressure, type of material cut, etc.) the specific components (pump type, nozzle type, accessories) and the water quality. The nozzle needs to be changed out fairly frequently to ensure precision cutting. Changing out a nozzle takes just a few minutes. Our MAXJET 5i nozzle is warranted to last 500 operating hours. The wear components in the cutting head need to be changed out occasionally. This takes approximately 10 minutes. The high pressure pump needs regular servicing. Our direct drive pumps are very easy to service and, depending on the pump model, a rebuild typically takes 1-2 hours. Accumulated abrasive and work material particles need to be regularly removed from the tank. The table slats should be inspected for wear at least once a month and rotated or replaced when worn.
What are options for used abrasive? Is it hazardous?
What to do with that used abrasive tends to fall into three categories: disposing, recycling, and repurposing. In most cases, used abrasive from a waterjet can be thrown out with other non-toxic garbage since garnet is a non-reactive, natural substance. However, if the abrasive has been used to erode toxic material and is contaminated with particles of toxic material such as lead or beryllium, it can't be simply thrown out with the trash and must be treated as toxic waste. A service that will periodically collect and properly dispose of your used abrasive can be employed to simplify this process.
How fast can an abrasive waterjet cut?
Cutting speed for abrasive waterjets is affected by multiple factors, including material type, material thickness, desired edge quality, part geometry, pump horsepower and more. Compared to other cutting processes, abrasive waterjets cut 5-10 times faster than wire EDM when cutting material less than 1 inch thick, and generally not as fast as plasma and laser cutters.
What kind of accuracy and repeatability does an abrasive waterjet have?
Table accuracy for OMAX line waterjets is ±0.0010″, for MAXIEM line waterjets is ±0.0030″, for GlobalMAX line waterjets is ±0.0030″ and ProtoMAX is ±0.0050″. The repeatability for the tables in both lines is ±0.0010″. Be aware that more than just the X-Y accuracy of a table goes into the final accuracy of a part cut on an abrasive waterjet. This is due to the nature of the cutting tool on an abrasive waterjet, a high velocity stream of water and abrasive known as the jetstream. Unlike rigid cutting tools, the jetstream bends as it moves and the lower part of the jetstream doesn't behave exactly like the upper part. The width changes and deforms and it tapers as it cuts. All of these things change with different materials, different thicknesses, different cutting speeds and a range of other factors. The control software on all OMAX abrasive waterjets uses an advanced cutting model that takes all of these factors into account and for each cutting job and optimizes the cutting parameters to make accurate parts every time. To get a precise measurement of accuracy for any abrasive waterjet system, get some test cuts done with your part designs and material and measure them.
